First Time Trolling
jrstables
I will be trolling for trout in a Northern California lake. I have no clue as to what a traditional trolling setup will be??? I have always fished from the bank......any info helps!! Thanks in advance!
mnewb1
Re: First Time Trolling
I am in a similar position this year hoping to venture out onto Lake Michigan for salmon and trout.
I got some good gear advice from folks in another thread. At this point I am researching down riggers vs using a dipsy diver.
rolmops
For a first time experience you should just go with leadcore.It is very forgiving and it is probably the cheapest way to give a good stealth presentation.
rolmops
what you need is a daiwa 57 and load it with one or two hundred feet of 50 pound power pro braid and tied onto this 10 colors of 18 or 27 pound leadcore (dependent on the size of the fish )On the business end you should have about 10 to 20 feet of 17 pound fluorocarbon and then either a lure or live bait on a hook with a stinger.The first hook tows the live bait,the second one does the catching.I like the 8 or 10 foot eagle claw rods,but just about any 8 to 10 foot medium strength rod should be fine.
heyyou325
What you need depends on what you want to catch. For trout or salmon, I like a baitcasting real. Mackinaw (lake trout) you might need 500 ft or more if you don't have a downrigger. I catch them a lot at 150 to 200+ feet. I just don't usually want to go deeper that maybe 250. With leaded line and 3 oz weights I figure I'm down less than 100 feet for every 200 feet out, there is a formula on most of the leaded line, at least what I get. Jigging works good for them too. Rainbow and some other trout, and kokanee salmon I usually get with around 50 to 100 feet out. A fish finder can tell you how deep to go, and be aware how deep the lake is. Your lure, bait, etc also depends on what you want to catch. 1 1/2 mph is usually a good speed to troll, but you will have to adjust , for the whims of the fish. A downrigger takes you pretty much straight down to the depth you want. It isn't quite 90 deg. but maybe 85.
I also like trolling a dry fly. Whatever bugs are on the lake (mosquitoes usually work good they're everywhere) with a casting float and 100 to 200 feet of monofilamant line oh say 15 lbs test, with about 5 feet of 2 to 5 lbs leader, also monofilament going from the float to the fly. They make a light grease or oil you can rub on them lightly to keep them dry, although I forget what that's called. You can also change flies every so often, like after every fish, and they will dry back out after awhile. Just see if the fly floats on top to see if you need to change. My father-in-law was an avid fly fisherman, and it used to really upset him the way I fly fished. Especially when I caught more.
fishrdan
What lake, what type and size of trout???
I've caught many rainbow trout on pop gear, worm (or lure) and a simple spinning rod loaded up with 6-8lb test. You could set up 2 rods ready to go fishing for $100,,, if you don't go crazy on high quality gear.
heyyou325
I've caught them sitting on shore casting too. He asked about trolling set ups. Fish finders and downriggers are optional, but very useful for fishing down deep. I've been skunked with them too. Dry flies work real good when they are feeding on the surface, and you can set yourself up real inexpensive. He can talk to people who fish there, and local sporting goods shops and reputable ones will tell him what they are bitting on and about how deep. I'ts the where that he has to work on. I've always been taught fish bite above themselves, so you want to be a few feet higher than they are.
Reel Kahuna
Do I need a special reel or anything??
It's difficult to answer your question with a "one liner" reply.
It depends on where, when and how you're going to troll.
Most die hard has downriggers to get the right depth where they mark the fish.
Others just use lead core line which is color coded ever 10'.
While still others will just "top line" letting "X"- number of feet out.
Type of rod, reels and line (braid vs mono) etc.
IMO, trolling is an art where one perfect their presentation which involves speed of the boat, number of feet of line out and maintaining the proper depth of where the fish are marked. Type of lures, color of lures, lure trailers, flashers/dodgers colors and so forth.
Again, not an easy answer.
BTW I sent you a pm which may shed more light to your question.
Tight lines
