fish finder
rwcreigh1
hello,i just installed my new garmin fishfinder but i do not have a windshield to protect it from water splashing on the back of it.somtimes here in galveston bay it gets very choppy real fast and waves have broke over the front causing water(salt) to splash all over.will this hurt it untill i get back.they claim it is water tight.how should it be cleaned i.e. sprayed off?thank you
Darren Smith
Re: fish finder
Without knowing wich model it is, it should meet JI-7 standards (30 second submersion up to 3.28 feet or 1 meter). Best check the model and cross reference the exact water resistance spec. But starting there, a wash or spray from sea water shouldn't hurt it. To clean it (assuming it is water resistant)simply spray it with fresh water and maybe a light soap and soft rag. If you have the manual it will be in the care and maintenance section, or post wich model you have and try google. Good luck!
rwcreigh1
Re: fish finder
it does say Waterproof design to IPX-7 standards but that does not tell me much as this is my first finder.
Darren Smith
Re: fish finder
The water resistance is HERE . 1 meter for 30 minutes. Shouldn't be a problem with spraying it with a light stream from a hose (not a nozzle at full but an open hose!) to clean the salt off. Something to remember that does NOT include the power cables and corrosion. I would recommend a good di-electric grease on the cable connections.
rwcreigh1
Re: fish finder
wow thanks so just apply the grease in the conection.where do i get that grease?and thank you very much
JB
Re: fish finder
Electronics topic.
