Re: fish finders: fish id or arc
Not sure why this was moved as I interpret this thread as a fishing question not an electronics question. But I digress.
There are a lot of assumptions made in this thread. dingbat makes some good points. But I have thoughts after covering the thread:
That makes perfect sense and i should have thought of it sooner. Of course you cant use a fish finder to find fish only the cover that they would be in.
All depends on what kind of fish and what kind of water you are fishing. Not all fishing is in cover.
I use sonar to find fish all the time! I NEVER use fish ID as it obscures everything useful and makes my good resolution pointless if all I am getting is fish symbols. I use sonar to find fish when open water salmon trolling, and open water or off-structure oriented roaming walleye for example.
There ain't no cover out there! I am looking for bait, and arches that indicate fish at certain depths. I also sometimes lower (at varying depths up to it's full 60' length) an electronic water temp sender and check temps at varying depths and
choose which arches to target if that information gets my attention. I have marked arches while fishing and suddenly adjusted lure depth based on the depth of the arch and often this results in a fish being caught. It is not a fish-finder, as pointed out. It is a sonar I use to help me find fish.
so for a basic unit with a small screen and gray scale would fish id be better
Fish ID is never better. It is a waste of good sonar technology. You want to see the results of you echoes, not the results of what the software is deigned to interpret for you. As far as gray scale sonar: I use a 480x480 grayscale sonar. It doesn't show those huge marks dingbat mentioned. Only occasionally for probably the reason(s) other posters mentioned. I do not like color sonar- yet. I like HDS and "scan" units and think they are pretty cool tools but I don't want one. Just give me sonar! And think about this: it takes three pixels to display a color, while only ONE pixel to display "black." So my 480x480 is 480x480 pixels resolution on-screen. However, take your color 640x640 and you get only ~213x213 effective pixel resolution.
Grayscale is better for general purposes. Structure scan I suppose has usefulness for bass or maybe some saltwater fishing. But as a troller for walleye and salmon and steelhead mostly my 480x480 helps me find fish. That, and it seems all the color units show those huge arches. My grayscale shows smaller, thinner arches. Often when walleye fishing I can predict the size of a fish if it hits as I have seen enough arches at "x" feet deep which were followed by a hooked fish that I now know what to expect.
....you can adjust that sensitivity and the frequency to see things that get in the way of the signals destined for the bottom....
Well, it is more than a fathometer. Most of what we enjoy for sonar today came out of technology originally brought "to the next level" during WWII with submarines. We have more tech on our boats today in that little box on the dash than the military did on warships in the 70s.
