Fisher Boat Help!
JDA
I recently bought a 1998 Fisher 16 Pro Avenger V-boat as a second,small water boat. The instrument panel shroud which is the molded plastic cap that houses the gauge cluster & switches is cracked and needs replacing. I tried the local Tracker dealer who said it was unavailable. I think several Fisher boats of that era used the same one. Do any of you guys know where I could possibly find one? The part # is 5037.
Thanks for your help!
beerfilter
Re: Fisher Boat Help!
Try EBay , also check other dealers and smaller shops . Chances are you may find 1 . You could also buy a generic replacement of similar size , or , fabricate your own .
Is that helm glass or abs plastic ? Might be repairable with a little glass and resin , then repaint .
