HotTommy
Thread starter- Joined
- Mar 15, 2013
- 1,025
I have a 24' pontoon boat with two U-shaped pontoons. It's about twenty years old and I bought as a rebuildable basket case last year. It came with a 90 HP Force outboard with power tilt. I got the whole thing up and running, and it served well for family fun on the lake last summer. Over the winter I purchased a damaged 150 HP Force outboard that I am repairing. I also replaced the motor pod with a much heavier grade unit capable of handling the added weight and power of the bigger engine. I also skinned the bottom of the boat.
My efforts to repair the 150 HP engine are covered in several threads elsewhere on this forum. It seems to be going well except for the power trim system. I haven't given up yet, but I may decide that the power trim system is not worth the cost and effort to fix it. And that brings me to my question.
If I do not repair the power trim system, I will just bolt some kind of spacer in its place. That means the trim on my boat will be essentially permanently fixed. Thus it would not be easy to adjust the trim at the dock for various loads and conditions. I will be able to adjust the size of the spacer after the first few times out, but after that I would leave it alone. Based on this concept:
- Do you think this will be a tolerable situation?
- Other than losing 1-2 MPH at the top, will I notice it?
- Is there an optimum engine angle to use as my starting point for adjustments (e.g., full down, full up, perpendicular to the waterline)?
- Can you offer any other practical solution that costs less than $300?
