- Joined
- Oct 25, 2011
- 25,329
Re: Fixing corrosion holes in my 1997 Monark Pro 1700
Has the water leak continued? From today:
That is a beautiful job! I'm jealous! I have 1997 Monark Pro 1700 that appears to be the same boat only 2' shorter. I have a question for you. I have some corrosion issues on the port side chine and I need to get to the inside where the bottom of the boat meets the side of the boat where all the rivets are. How hard is it to remove the carpet and anything else so that I can see that rivet area? My damage is between the dash board and the step that has the batterys under it on the port side chine. It's bad enough to where the boat leaks. Any help would be greatly appreciated. Thanks.
