You will want to drill a small hole at the very end of the crack(s). This will stop the crack from spreading further and then you patch over it. By removing the end of the crack with the drill bit, there is no other place for the crack to spread.
May not be the case with fiberglass/gelcoat but this method works for everything else, dont see why it wouldnt work in this case.
Good luck!
