Fixing trim gauge
thedinz
Hey all, my boat trims up and down fine, the gauge just doesn't work, i replaced all gauges and all my gauge work except this, I have checked the wiring and that's not the issue.
I am doing some outdrive work so it seems like a perfect time to replace my trim sender, could this lead to the gauge not working?
Scott06
absolutely #1 place to look.
Here is a thread that gives ohm rating for sender diff between sender and limit switch
guy48065
Also check the short ground screw on the sender isn't cut or corroded.
Do you have any pics, I just picked up a 1991 Rinker Captiva 206 and the trim gauge is inop. Thanks in advance
