flapper valve question
Status
Not open for further replies.
tboss
I have a 1986 c/c with a alpha1 O/D on a 350 engine can some one tell me where the flappers are located in the exaust are they up high close to the manafolds or down low at the bottom of the exaust where it goew thru the gimble assy. I want to check mine but need to know where to start. tks terry
Re: flapper valve question
Ayuh,...
In your boat, they should be mounted in the Top of the Y-pipe....
tboss
tks bond-o I will check there
Keithowsley
I have a alpha 1 gen 1. On my mercruiser 470
And I replace the gimbal bearing and bellows and water impeller pump and reassembled
I noticed some talk about a flapper valve
Is there one one my boat and if so where is it?
Status
