I just purchased a new boat and I have a Garmin 176C Fishfinder/GPS and a Lowrance 1440 flasher unit. Both transducers are mounted next to each other on a mounting board on the transom.<br /><br />The flasher is going crazy, reading 100 ft. then 60 then 20, back up to 100 ft, etc. I've tried every setting possible, i.e. manual sensitivity (ranging it everywere), low & high noise reduction (I've waived chicken feet over my head and said a prayer), etc. Today, someone told me that he would bet that the fishfinder is interfering with the flasher unit. He said it is not wiring interference but at the transducer level. He said he's seen this before and the only way around it is to turn off the fishfinder when you run the flasher. It's possible I can disable the fishfinder part of the Garmin (presumably eliminating the interference) so I can still use my GPS. If I can't, that's going to stink because I'd like to run the flasher and map at the same time when I'm running high speed.<br /><br />Anyone familar with this problem that can enlighten me?<br /><br />Thanks,<br /><br />Rob
