I have a '68 Lazy Days houseboat with a fiberglass roof. I replaced a section that was rotting, from side to side and about 4 feet from back to front, replacing the plywood beneath and new rafters/joists then covered it with new cloth and West Marine resin. It all cured out very well and I covered the new section overlapping and also covered the old section that was still good to cover spider cracks and it all seemed great. But! After a while the section I replaced being about 1/16" or so lower and tending to flex a tiny bit caused a crack in the fiberglass between the old and new section. I applied more resin and it looked great again. But! After a while there was that crack again. So? Can you folks suggest a dependable flexible product to cover the crack with that will last for years and can be painted over? I was thinking the 3M 5200 through hull caulk might be a good choice. Or maybe White Lightning 3006 40 year caulk. Or are there better products you people can recommend that I have no idea about?
Thank you for any help with this!
David
Buford, GA USA
David
Buford, GA USA
