Silvertip
- Joined
- Sep 22, 2003
- 28,772
Re: flipping axel to the top of the leaf spring
To refine this flipping business some more, you can flip any straight axle -- we are all clear on that. If you buy a cambered axle without spring perches, they can be welded on top or below the axle for below axle or above axle mounting so that's not an issue either. But unless you cut off the old perches on an existing cambered axle and install new ones you cannot flip a cambered axle for the simple reason the perches are in the wrong position. I suppose I should clarify what a cambered axle is for those that don't know. Take a straight axle and put a slight bend in the middle. The purpose of this is to allow the wheels to take a slightly "cambered" stance (tilted in at the bottom and out at the top) so when the trailer is fully loaded, axle and suspension flex allows the wheels to run closer to straight up. Thats why you need to specify an "oversprung" or "undersprung" axle when ordering a new cambered axle. They are not interchangable. Here is a diagram of an axle mounted over the spring. The rectangular block between the spring and the axle is a spring perch which is welded to the axle. If this was a straight axle (no bend in it) you could simply rotate it 180 degrees and install it beneath the springs. However, if it were a cambered axle, rotating the axle 180 degrees would place the bend in a downward rather than upward direction so a sever camber issue would exist. If a simple through hole is used in the axle and spring perches are not used, then flipping can be done.
