Trying to fit a new flo-torq II hub assembly kit & new Quicksilver 17 prop. to a pre-alpha stern drive .
My question has to do with the washers behind the prop. there is a single fairly thick washer then the rather large thrust washer do these stay in place ? If so do you then put the new thrust washer that came with the kit between the old thrust washer & the prop. I tried installing without the old thrust washer & resulted in the prop being wedged & seemed to tighten against the gear housing ..I did not torque it.
