Pescadora
- Joined
- Oct 25, 2006
- 37
This is a follow-on to the Enertia thread I started, where somewhere in the posting I mentioned an occassional rattling vibration at idle that does not occur with aluminim props.
The "chugga-chugga-chagga" sound with noticable increase in vibration. Nicking up the idle immediately cancels the effect.
I've been exploring the use of the FT IV hub for my 2005 F150 yam ever since. I've found a source for the parts but they are not returnable, which means you have to do your homework before plunking down the cash.
In the pictures they sent me, it looks like the inner splined collar which rides on the output shaft now extends fully through the delrin insert. The thrust washer appears to have its own collar which rides inside the forward end of the splined collar. In this rig, the forward half of the Delrin spacer engages the square cavity in the prop, while the back half does not. The back half engages only the output shaft. The two halves are mated with titanium rods molded into both sections.
Under power, the titanium bars flex, in effect acting like torsion springs which absorb vibration. The design won awards in the plastics industry.
But the questions for me remain:
1. Do the Yam F150 and the Mercury Verado have identical splined output shafts on the their respective gearcases.
2. Are the thrust washers for both engines are the same.
My engine came from the dealer with a FT II hub kit and a Merc prop. IF the answers to 1 & 2 are both yes, then the FT VI hub kit is a bolt-on.
