I got a new used carb with same body # and when I opened it up the float needle was different. The one that came on the origanal carb had a "hat" that a retaining clip attached to and then attached to the float hinge but the other one did not it just sat inside the hole under the float hinge. I put the one from my broken carb in with the clip. whats the differance?
