float setting for carb in a 74 ted williams 4.5 ??
jwh
Hi! All,
Am rebuilding my carb in my 74 Ted Williams 4.5 HP Mod# 217.59464 . The float sits a little uphill from the hinge out. Does it need to be level with the rim of the carb body to be properly set? The bowl has a raised area that I am sure allows room for the float to rise? Any help would be greatly appreciated. Thankyou John
M
mrcrabs
Guest
Re: float setting for carb in a 74 ted williams 4.5 ??
The float setting will require an​
11/64" drill bit
The inlet needle hooks onto the float tab by means of a spring clip, the open end of the clip must face the choke end of the
carburetor.
Yes that raised area is for the float to set in.
You also want the orange fuel pump element's slot to set at the 8 O'clock & 2 O'clock position
jwh
Hi Mrcrabs, Hope you are doing well. Is the 11/64 drill bit used as a guage between the float and the rim of carb(at the oppisite end of the hinge? Thanks again for your help.Also thankyou for the orange fuel pump element setting. I appreciate it. John
MahtyMaht
Bingo! You are correct, sir.
jwh
Thankyou so much for your help. John
jwh
mrcrabs, just wanted to let you know the Ted Williams is running great. Thankyou for all your help. John
M
mrcrabs
Guest
Great....there fine little engines and I hope it brings you alot of joy....take a kid fishing:)
