Float settings
cbeam2
Do you set your float parallel to the bottom of carb with is upside down? Or as the service manual instructions with the float hanging down?
Chuck
ezeke
Re: Float settings
Turn the carburetor upside down and set the bottom of the float parallel to the mating surface of the carburetor body. Then turn the carburetor body right side up and set the lower face of the float as specified for your engine. I believe the drop measure is one inch +/- 1/8 inch from the mating surface to the bottom edge of the float.
If adjustment is needed be careful not to put pressure on the needle, which could damage the tip. Also be sure to install the spring clip from the needle to the float arm.
jtexas
Re: Float settings
myself, I just use the upside down/parallel method...no special tools, no precise measuring, always seems to work.
ezeke
Re: Float settings
There is a small tab just off the hinge on the float arm. If the tab is set wrong, the float may not drop properly, which is the reason to check the drop.
