auto float switch not working on bilge pump. I have bilge pump connected to Atwood auto float switch. the last couple of times I left boat it accumulated water in the bilge, as soon as I removed the cover from the float switch pump turned on a worked properly. the float has some crud on it and I cleaned it a bit don't see anything else out if place, thought maybe an air pocket trapped under cover prevented float switch turning on but there are 4 unclogged holes in top of cover. Any ideas? thanks
