floor cutting tools
ecblanks
Looking for suggestions for tools to use to cut out bad oil-soaked sections of my floor(don't ask). It's 3/4" ply, obviously with a coat of glass on it. Right now I'm using an angle grinder with a metal cutting disk, but it's not working that great. The stringers are in pretty good shape so I'm trying to keep from cutting into them. <br />Any advice?<br />thanks.
snapperbait
Re: floor cutting tools
Be VERY carefull if you try this....<br /><br />A circular saw with the depth set to 1/2" - 3/4" would do the trick if you can get it into the areas you're cutting.. Just remember, the blade will get trashed by the fiberglass, so don't use your good blade...
Yep....<br />Fine Tooth Carbide..........
