l008com
- Joined
- Jun 14, 2007
- 751
I'm grinding the paint off my old floor. I borrowed my uncles air compressor and air grinder tool. What I didn't realize at the time was that the air compressor is severely inadequate for constant use of the grinder tool. I originally planed on working on it all weekend long, and finishing the floor this weekend. Well instead, this is all I got done:
The paint is grippy paint, the kind that has sand mixed in. I'm trying to get the floor bare, and I also want to hit the walls. But they don't have to be bare. Just smoother so when I put new paint on it, its more smooth. This time when I paint it, I'm going to use non-grippy paint except for on some specific walking areas. Using it everywhere wasn't a great idea. So I have a 3.5CFM/15Gal air compressor, and I'm using one of these air tools with 4" discs (happens to have a tiny disc in this picture, but the ones I'm using are much bigger.
It works really well, except that I get about 2 minutes of use, then 10 minutes of waiting for the pressure to build back up.
So I'm considering my alternatives, because I don't want it to take two months to finish this particular job...
I looked into renting a bigger compressor. I can get a 16CFM compressor for $65 per day. But that still might not be enough air for continuous use. And I still might not be able to finish the whole floor in one day. That's going to get pretty pricey, pretty quick.
Someone suggested a belt sander, would that be appropriate to use? Do they make 'belt's for them that would be good to use for this kind of paint, but that wouldn't dig into the resin too much? These discs I'm using seem to be absolutely perfect for the job.
My discs:
I feel like, if i used regular sandpaper, the sand in the paint would tear up the sandpaper. But I don't know, I've never done this before.
How would you guys go about removing grippy paint from your decks?
My discs:
