Re: Floor replacement question
Lots of progress this weekend.
A picture of the transom with the first layer of 1708 tabbing(8" wide) dry-fit:
The transom after tabbing the first layer:
The transom after tabbing the second layer of 1708 (12" wide):
As you can see in the above picture, the tabbing has covered the "wings" and much of the transom.
Finally, a picture of the transom after two layers of 1708 on the whole thing:
I did it the full coverage layers the way Friscoboater did in his video. The first layer is about 2" smaller on all sides than the core, then the second layer is the full size so that the edges don't line up over each other. There is a lot of 1708 on the transom, the "wings" have up to 6 layers in some places due to overlap of the tabbing pieces.
I felt comfortable enough to try attaching both full layers of 1708 with one resin mix. It worked out well, the resin didn't kick until about 10 minutes after I was finished.
The transom glassing is now done. Tomorrow I'll cut out the outdrive hole and the drain hole. Then it's on to the stringers.
The stringer that I was gluing up also was ready this weekend. There was some unused resin left after the second tabbing, so I used it to coat the stringer with. I found that its good to have something ready to take any extra resin that is left over instead of throwing it out.
Here's the first stringer blank after gluing and resin coating:
