Floor storage compartment for toon
rickdb1boat
Just wondering what ya'll think about putting a 6" deep by about 2' X 3' storage locker on the floor of my toon? Would this interfere with the splashing that occurs while underway? My crossrails only stick down about 3" or 4". Would it be better to put it in the front, where it's mostly out of the water at speed? I really wanted to put it in the back, but I'm afraid it may interfere with water flow. Any ideas?? Could I taper it toward the front to avoid this if I put it in the rear? 3" deep is not really deep enough for what I what to store. Thanks,
neumanns
Re: Floor storage compartment for toon
I don't know rick but I had considered putting pvc pipes under mine for rod storage. Proabably will one day cause I hate leaving them and I dont like always stowing them for trailering. Hope someone is more help than me.
rickdb1boat
Thanks for the reply! I'm still not sure what I'm gonna do. I hope others wil have some kind of idea.
river rat 26
I hung a gas tank under mine, big mistake. I could feel it tugging all the time, very annoying. It was about 9" tall. I think just about anything is gonna create some drag.
BillP
Build a long narrow "pod" with vee shape and mount it under the deck. Build it from pt plywood and seal around the edges where it meets the deck. Then make a hatch through the floor for access. <br /><br />The pod could have drain holes just in case water gets in and items would be stored in waterproof bags used for kayaks. I use the bags for kayaking and they are 100% dry, even if dunked. Cheap ones can be found at Walmart.<br /><br />There is a company that makes pricy bolt on fiberglass sponsons similar to this in large scale for pontoon boats and claims higher speeds with better fuel economy.<br /><br />I've got a 20' toon so know what you are looking at under the deck.
