Fluid in float...
Skeeter54
So I took the top carb off my 84 Mercury 115 and noticed there is fluid in the float. I read this was somewhat of a common issue in older carbs. I have read there is no real way to get that fluid out easily. Problem is I can't seem to find a float to replace it. Anyone have a replacement part # or idea on how to clear it? I havent even opened the others yet so who knows how those will be.
Skeeter54
found the part! now my only question is are the floats the same on the middle and bottom carb? may be a dumb question but first time doing this
emckelvy
Yes, they are; the floats in all 3 carbs are the same. Haven't personally seen a lot of failures in the newer-style plastic float, but things do happen! The hollow-chamber style of that float would make it more prone to getting a leak and filling with fuel, whereas the older foam-style-plastic floats just tended to soak up the fuel and get "waterlogged".
If you're going thru the carbs, it's always a good idea to check the floats, set the float level and make sure the needles and seats seal like they're supposed to, and flow as they should. New needles & seats are still available, BTW, if needed.
FYI that same float style has been used since the 50's, ain't that a kick!
Something that I didn't know, I checked and the hollow-style float has been superceded by an even newer-style float, that looks like foam again. Maybe the hollow floats were springing more leaks than we knew.
That being the case, it might not be a bad idea to order (3) new floats, to avoid problems in the future.
Cheers.......ed
p.s. the Sierra Marine aftermarket floats (P/N 18-7208 are a lot cheaper!!) And lots of times you can order them thru NAPA.
Skeeter54
yup, thats the one I found!! guess i'll be ordering 3. Thanks emckelvy!
