stratcat88
Thread starter- Joined
- Nov 16, 2009
- 174
back again. god save Iboats! the mech. i hired to install my nitemare, i mean engine installed a water cooled system and the water pickup is through the hull. he blocked off the pipe from the stern drive through the transom with a big bolt.about the only thing my engine does right is cooling. the problem is their is green fluid coming out of the starboard side water inlet on the lower unit. im thinking that caused the leak. if so, can i plumb that hose into the seawater pickup pump hose before the power steering cooler? thanks again tim. oh sorry, 1980ish 350 mercruiser with alpha one drive. no #s
