Fluids in stringer outdrive leg
oldsub86
I seem to recall reading somewhere that one could use normal gear oil in the upper part of the leg and in the intermediate housing.
I know type C is needed in the lower unit to ensure that the electric shift will function properly, but is there any reason that it needs to be used in the upper?
Boomyal
Re: Fluids in stringer outdrive leg
New people see your posts and do not have a clue what outdrive you have. Even those who have seen your posts before do not remember what you have. That being said, I assume you have an electric shift, it takes the type C. No reason you cannot use any 75w-90 (or equiv) in the upper and intermediate housing. The only difference between 'normal' gear oil and marine gear oil is the anti-corrosion and water disbursement additives. Marine lube will continue to effectively lubricate even with water mixed in. (up to a certain point)
If you do have the electric shift OD, you do NOT want to use the lower lube in the upper and IH gear cases.
oldsub86
Thanks for your response. I guess I could have included more of a description of the outdrive, but this is on the OMC forum and I did say "stringer" in my title line and I did note that I knew I had to use Type C in the lower unit so that the electric shift would function properly. Normal gear oil is too thick and I understand that poses problems for the electric shift.
I have bottles of Marine gear oil around that we use on the outboards but I do not have any Type C and I am about ready to try this boat and see if it works. Type C is becoming harder to find. FLAPS used to have it on the shelf but not anymore so I would have to go to a marine store and hope they had it on hand.
The lower unit has oil in it and I won't change it out until I know this thing at least moves under its own power.
I filled the intermediate housing with marine gear oil and I guess I am going to do the same with the upper part of the leg.
Boomyal
....nor do you want to use 75w90 (or equiv) in the lower unit of an electric shift OD.
