Re: Flushing an outboard ?
Hello Bill. When asking about flushing an outboard I am quessing you are referring to the cooling system. Generally flushing is done after a trip out on the water to clean out the cooling system. Mostly it is done when the motor is used in salt water since salt water will corride aluminum when left in it for extended periods of time.
Steps to flush engine. Using a good set of muffs, which go around the water intake on the lower unit, apply just enough water pressure to get a small amount leaking around where the muffs fit on to the lower unit. Start the engine and make sure you have a pee stream out of the tell tale hole and still have a small amount leaking around the muffs. I use a inline water valve with a 10 foot hose between it and the muffs. I put the inline valve over the gunnel so I can turn on and off the water and also adjust the flow while running. Let the motor run for about 5 minutes then turn the engine off, remove the muffs, let the engine drain and your done.
Personal note, I like to pull the fuel line to run the fuel out of the carbs during the last of the engine flush and stop the engine when it starts to stumble. This keeps the carbs from leaking when i tilt it up and helps prevent carb gum from building up.
Durwood
