Flushing motor
mountainboy
Just before taking the boat out of the water,<br />it is necessary to always disconnect the<br />fuel line and let the engine run until it dies?<br />I've heard different theories on this. I have<br />a 1984 9.9 evinrude outboard. Any info.<br />is always greatly appreciated! MB
Tracy Coleman
Re: Flushing motor
mountainboy<br />Not unless you want to have regular carb problems.<br />While in the water, disconnect the fuel line at the motor and run at a fast idle 'til it's about to die, choke it 'til it quits. If you use it daily or several times a week, no reason to to it.<br />Use it once a week, a month or less it is the smart thing to do. Smarter is to use OMC product 2+4 fuel conditioner in fresh fuel- to keep it fresh in the tank- still run gas out of the engine. On larger engines with oil injection, do not run the gas out, use fuel stabilizer/ conditioner in the fuel. For off season storage, put one ounce of Evinrude outboard oil in each sparkplug hole, replace plugs and pull the rope slowly once or twice.<br />Backfire ;)
