Flyweel removal
pescado64
I need to know if its possible to install a flyweel on a 350 GM engine backward?
pescado64
Re: Flyweel removal
because i just replaced my bayliners engine, and the starter doesnt seem to be engageing.
chiefalen
Re: Flyweel removal
And the coupler fit, and it fit back together in the bell housing??
Whats happening when you turn the key the motor is not turning?
It could be the wrong flywheel, or the starter bendex is not fully extending.
You have it back in the boat? And didn't start it on the crate?? I mean stand ??
Did you replace it with the same year motor??
Pull the motor back out and start over ?
I know, i know it's alot of work, next time start it on the crate for a minute.
Re: Flyweel removal
Ayuh,... Not without it being painfully Obvious....
Are you using the boat's original Flywheel,..??
Are you using the boat's original Starter,..??
Or,....
Are you just Mixing,+ Matching a Pile of Parts,..??
legoman67
Re: Flyweel removal
did you change the position of the starter? Is the starter engaging properly? Did you buy a new starter or reuse the old in the hopes that it works? I just had to swap flywheels on my new engines because it was setup for offset starters, and i had to install inline to fit the engines in my boat. I had to use the flywheels off the old engines.(same block)
pescado64
Re: Flyweel removal
sorry guys for the delay Im at work. Anyways i am using the same flyweel i had on the old eng. the new eng. is the same size as the old one, i am also using a new starter. the eng does not turn at all with the starter. thats why i was wndering if i probably put the flyweel backward.
chiefalen
Re: Flyweel removal
What i was trying to convey is the flywheel might be hanging up on the bell housing.
So yes you might have put it on backwards. The coupler usually sits in a groove of the flywheel sorta a recess did it when you put it together ?
Re: Flyweel removal
Ayuh,...
Is the New starter the same bolt pattern as the old starter,..??
Is it Binding, Screeching, or just plain Missing the ring gear all together,..??
