flywheel holder &more
forrealcc
where do i get one local.im ready to tear this 115 hp 283xxx mercury down.well installing a new disb.and stator .any other steps installing this stuff would help i did download the manual from the sticky:D where can i get the puller or make one and thread size on the puller threads.
Chris1956
Honorary Supreme Mariner
Re: flywheel holder &more
If the timing belt is good, you may simply remove the eight 5/16" bolts and take off the outer flywheel. Heck, You might even be able to install a new timing belt after removing just the outer flywheel. The starter may be removed w/o removing any part of the flywheel,
forrealcc
can i get some correct info please ............
im in stalling a STATOR,not a starter......
and a distrubtor assembly .........
Chris1956
A stator on a distributor Merc fits around the inner part of the flywheel. You may just remove the outer flywheel to replace both.
forrealcc
Forreal i can change the distrubtor and the stator by removing the 8 5 \16th bolts.could i use two wrenchs to hold the flywheel from moving then?i dont see it this way in the manual.but im game if its right .
Chris1956
You can jam the flywheel ring gear with a screwdriver to the block, socket on the flywheel nut, or use the outer bolts on the flywheel to hold it, with a wrench. Use some blue locktight on the distributor pully bolt and the outer flywheel bolts, when you reassemble.
forrealcc
thanks chris 1956 .im torn down sir .distrubtor off the STATOR( LOL) is off .thanks for the tips.so i havethe 8 bolts from the center out to remove flywheel the stator and belt.and you can change the belt like this ,your the man:Dbut im not doing that because some one must of just changed it !!!!!using your method because the 8 bolts in the center that i took off already had the red paint chewed up on them from putting the new belt on .so ahead of schedule.BUT what do i torque them too and should i put a drop of locktite?
Chris1956
Use blue locktite. Torque to the standard for 5/16" bolts, aw heck, just make them tight, one hand on the wrench only......
