FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 77 Evinrude 140hp and i've sheared the key for the third time.Any ideas as to whats causing this.The crank does have some surface rust on it should i use some emery cloth to clean it up.
Are you using a OEM key or one from the local hardware store!? Hardware stores won't work. And if you are using OEM, are you torquing the crank nut down to spects? Post back? Post back results.
You need to lap the flywheel to crank, this is stated in the earlier service manuals. Just remove key and apply valve lapping compound to the crank. Slide the flywheel on and spin the flywheel over the lapping compound. Start with the coarse compound and move to the fine compound. When finished, thoroughly clean all of the compound off of flywheel, keyway and crank.
Examine the slot in the crankshaft as well as in the flywheel. If the slots have been worn by previous shears, it will only get worse. The key must fit snuggly in both the crank and flywheel.
The key doesn't hold the flywheel on. It's only there for proper timing position. You have what is called a "morse taper" between the flywheel and the crankshaft. Both surfaces on the c/s and f/w have to be clean and shiney, dirt and oil free. Then the f/w has to be torqued properly. As Faztbullet suggested, the lapping is a good idea. When you install the oem flywheel key it's outer edge has to be parallel with the center line of the c/s.
agreeed what boobie said is THE most important part the key MUST have the flat side parallel to the CL of the crank and it will shear EVERYTIME if you have it follow the taper
Key must be correct grade steel hardness to shear with good tight fit in woodriff on crank and flywheal no oil what so ever torq to mfg spec and see what happens . use permanet marker or blueing to see if taper is matched
