Flywheel Key
seakas
1953 Evinrude Fastwin 15.....the flywheel key keeps breaking.....anyone had a similar problem? what could be the cause??? Stumped!
HighTrim
Re: Flywheel Key
The most common causes are improper key, and improper torque.
Do not even bother trying to use a hardware store key, they will break. Get an OEM key from your dealer, and torque it to 45 ft/lbs
Also, the taper of both the crank and inner flywheel mating surface need to be clean! Wipe off with acetone before installing.
schematic
Re: Flywheel Key
As mentioned above, you may need to "lap" in the tapers because broken keys often damage the taper surface.
