Flywheel number for 4.3 v6 vortex engine
dlogvine
Im looking for the flywheel for 2002 vortex mercruiser v6 engine. Cant find what serial number does it have. If anybody knows it, would really appreciate your help.
2002 silverado 168 tooth GM flywheel for the 4.3. about $70
however most likely you need only a ring gear which is about $15 at napa
dlogvine
Nay, I got the block with some extra accessories, flywheel was missing.
Thank you very much. So regular automotive flywheel would do? There are several 168 tooth flywheels that differ by the weight for different Chevy engines. Mercruiser numbers are also different from Chevy casting.
mercruiser bought the motor complete with exception of manifold up and exhaust from GM. the flywheel is a GM flywheel.
there is only one for a 4.3 manual transmission. with 168 tooth ring gear.
Ayuh,..... Like Scott said, there's only 1 flywheel Chevy was puttin' on that motor, with a manual trans in 2002,......
That's the one ya need,...... the coupler bolts where the pressure plate would go in a pickup,.....
dlogvine
Thank you guys! I really appreciate your help and knowledgeable advice!
