Flywheel porn
wired247
40 amp 6.5 lbs. I gots more dollars than sense...
wired247
Re: Flywheel porn
Should be OK. Ive got a Brucato ACU and the idle quality with those is considerably better than the factory ECU. I havent heard of anyone complaining about the idle with the lighter wheel. I was running a 10 lb 16 amp setup so its not much of a difference but the 16 amp had a problem keeping both fuel pumps running and firing the injectors and charging the battery. I'm just not happy about running a factory 40 amp flywheel over 7000 RPM.
CharlieB
Re: Flywheel porn
Nice piece, who makes it?
How are the magnets held in place? Glued or clamped? Combination?
wired247
Re: Flywheel porn
Jeff Dunn makes them . Hes got a running ad on the S&F board. Its a combination of clamp and glue. CNC machined and very well constructed and he sends them out for balancing .
wired247
Re: Flywheel porn
Enough to make your eyes water. Smooth as silk.
