Re: Flywheel Problem.
Warped flywheel from the 2 screwdriver approach? Warped/bent stator plate? Place the flywheel on a piece of glass & inspect w/feeler gauge all around. Should use a flywheel puller & never pry one off or use a puller that applies pressure to the outside of the flywheel. You may have cracked the flywheel @ the bore that sits on the shaft & this is allowing it to pull down lower on the shaft under torque.
