flywheel puller bolt size??
Status
Not open for further replies.
fishingdave
I have a 89 90hp johnson, and i need to know what bolt size are the holes on the fly wheel. The bolts that i was using seemed to be the wrong size and pulled right out, luckly the treads on the flywheel arn't bad of shape
OBJ
Re: flywheel puller bolt size??
I believe they are 5/16 NF Dave. Funny, I got a harmonic puller and never measured the threads for the puller bolts. :confused:
DHPMARINE
5/16 fine is correct.Two other reaons for bolts to pull out.<br /><br />Nut still on flywheel.GRIN<br /><br />bolts not threaded in far enough,or unevenly.<br /><br /><br />DHP<br /><br />OH yeah,air impact wrench.Use a breaker bar and a flywheel holder.
OBJ
Thanks DHP!!! Just blew Bud all over the monitor!!!..... :D :D
G DANE
The motors smaller than 35 HP need 1/4"
R.Johnson
The best bolt to use is a shouldered stripper bolt solt by machine supply dealers
BoatBuoy
Shouldered stripper bolt? Pls describe further.
OBJ
Right after the threaded part, there is a flat shoulder that fits flat against the flywheel once the threaded part is all the way in. This makes the pulling bolts equal so the pull on the flywheel is equal around.
R.Johnson
A stripper bolt such as you want for your engine is a 5/16- 24 thread. The body of the bolt is smooth, and is 3/8, or .375 in dia. The business end of the bolt is turned to 5/16, and threaded for 1/2 inch up to the shoulder of the smooth part. The bolt is screwed in up to the shoulder, and tightened securely. This takes the strain off the threads in the flywheel. The smooth body of the bolt is 1 3/4 in. long. This is the bolt supplied with the OMC puller.
BoatBuoy
I know exactly what you're talking about. I just hadn't heard that name for them before.
OBJ
Thanks RJ....you 'splained it lot better than I did.. :) :)
Sharper49
What size bolt and thread do I need to remove the flywheel off of my 1995 70hp Johnson outboard
Status
