Re: flywheel removal
Hooty is right. I have heard that anything that could lubricate the surfaces between the flywheel and crank will let the flywheel move too far down onto the crank and you wither will have the flywheel hitting things or more likely, never get it off again. If you use penatrating oil , make sure you totally degrease the crank before putting th flywheel back on. Of course, you have to get it off first. Good Luck
