Casanovass
Thread starter- Joined
- Apr 19, 2008
- 2
I have a yamaha 100 1992 4 stroke and am looking at changing the timing belt myself. Just after some advice on how to remove the flywheel. If I remove the nut that holds the flywheel on. Then use a 3 legged puller to latch under the teeth of the flywheel and tighten the puller up , finally give the top bolt of the puller a sharp hit with a hammer this will pop the flywheel off the taper . Would anyone know if this is the correct way to do it ?
Regards
Regards
