Flywheel removal
tznl
I am trying to remove a Flywheel from a 1990 Johnson 225. Can someone tell me what size nut holds it on? I tried a 1 1/4" and that's too small and a 1 1/2" socket doesnt fit down to the nut.
wayne h
Master Chief Petty Officer
Re: Flywheel removal
i belive you eather need to find a thin wall socket (not that easy) or turn 1 down yourself on a grinder its 1 1/2 i had to grind mind down on the bench grinder to fit
DHPMARINE
tznl,<br /> Maybe they changed the size,but most V6's are 1 7/16.and yes you may have to grind down the outer diameter to get in there.<br />DHP
