Flywheel remover
spy1309
Do you guys know where can I get the Flywheel remover?the one shown in Seloc manual or something close.
All the auto part I went to have the wrong one. or there is a part number for it?
Your input is appeciated.
F_R
Re: Flywheel remover
Harbor Freight has one. So will any decent auto parts store. It's called a vibration damper puller. Don't waste your time on a el-cheapo cast aluminum thing. You need the strength of steel. With a 3/4" diameter fine thread center bolt. You also need hardened Grade-8 bolts to go with it. The cheap bolts just won't do and you will be drilling them out when they break.
Or you can go to a dealer and get the real thing made for their outboards for 10 times as much money.
spy1309
FR you are always on the spot thank you, the grade 8 bolts I have to buy them separately? and if yes what lenght and diameter?
F_R
As suggested, the bolts size varies according to what you want to use it on and the thickness of the puller you get. Auto parts stores generally have Grade-8 bolts but I've heard horror stories about some of the prices some will charge. They should not be outrageously expensive.
spy1309
Problem solved, went to NAPA auto parts and got a nice one for $17, is made from steel, and have 3 sets of bolts with it for diferent lenghts.
Thank you.
spy1309
FR do you have any ideea where I can find 1/4 bolts grade 8?
I got some from Home Depot, Menards they snap like candies even do they are not the cheapest quality.
Everything I find grade 8 is 1/2 and higher and the bolt from the set are to large.
Rick.
Grade 8 cap screws (bolts) are available in sizes from 1/4 inch and up in all the popular lengths. Try an automotive parts store or better yet a farm equipment repair shop. Rick.
