flywheel torque help
Sea Raider I
How does one man torque the flywheel bolt down to 105 ft/lbs by himself???? Is there a way to lock the drive without using a piece of wood between the prop and the LU?? Any suggestions appriciated. BTW its a 18 hp 63 Fastwin....
Daviet
Re: flywheel torque help
I use a automotive flywheel holding tool, it engages the teeth on the flywheel so you can hold it.
seahorse5
You might want to double check that 105 ft. lb. torque spec on your "small" 18hp flywheel nut. Sounds a mite steep.
Use a strap wrench on a smooth flywheel or a flywheel holder on a toothed flywheel.
boobie
The torque spec is 40/45 ft-lbs for the flywheel.
Sea Raider I
Thanks, assuming under torquing to the correct specs will ultimately shear the pin, will overtorquing have the same result?
wilde1j
Wrong torque will usually cause the flywheel key to shear. Do this a few times and the flywheel and crankshaft become junk.
Sea Raider I
Thanks guys, I went ahead and set to right torque - 45lbs is much easier by yourself..
