jbuote
Thread starter- Joined
- Aug 17, 2016
- 1,001
I've recently read posts about folks replacing flywheel keys, and I've replaced mine as well.
Each and every time, I've seen that you should NEVER use hardware store type keys as they won't hold up..
To be CLEAR... I agree wholeheartedly that original factory parts should be used. I use only factory or third party direct factory replacement parts. Just like the factory key I bought for my Johnson..
The curiosity question then, is this...
The taper of the crankshaft and the flywheel is really what holds it together. It's a press fit when properly torqued.
The taper acts as a lever holding the flywheel in place. (when properly torqued).
The real purpose of the woodruff key as I understand it, is to properly align the flywheel on the crankshaft during installation. Then once it's torqued down, then the taper press fit holds it in place.
So why does the strength of the woodruff key matter at that point?
It's been a LOOONG time since I've worked as a mechanic in auto or learned about Aircraft maintenance, so I'm SURE there's something I'm missing and/or forgot.
Anyone care to refresh my memory, or enlighten me?
I love learning/re-learning information!!
Thanks!!
Thanks!!
