Flywheel
noah4009
My engine wont start and it did before I did the fuel pump and cleaned under flywheel. I am getting spark. When I removed flywheel I also pulled strator off without disconnecting and I remover breaker plate. I cleaned breaker plate and put grease on its side. (tower was sticking, this fixed it) I put strator back on. As I said I did not disconnect, It slides back on and in same position cause it has holes for bolts to go thru. Put woodruff key. I cannot see anything I could have done wrong. After doing more reading I am beginning to think I screwed up the timing. I also removed the spark control link and spark control bearing. This according to the manual is used to set timing. Did I screw up the timing? Help
moparman
Re: Flywheel
what motor do you have? Alittle more info would help us try to get you going .thanks moparman
noah4009
Re: Flywheel
1971, 55HP Chrysler. Model 557HC serial 3188
