Flywheel
joenapier
Before I stand on my head and count teeth, anyone tell me the size of my flywheel - 14" or 12.75"?
1985 Merc 260
Century Arabian
sharkin95
Re: Flywheel
In that year they had both flywheels 12 3/4 and 14, I think the 14" had the triangle shaped coupler and the 12 3/4" had the round coupler.
Re: Flywheel
1985 Merc 260
Century Arabian
Ayuh,... The Starter is held on by 2 bolts, straight up from below,...
Reach under, 'n feel 'em,...
Straight across bolts is the 12" wheel, 'n the staggered bolts are the 14" flywheel...
joenapier
Re: Flywheel
Here is the starter that was swamped with seawater. The bolt heads are staggered, but the mating surfaces are on plane. From your advice, this is for a 14" flywheel then.
Here is my problem looking at the starter only - I know this is not original to the boat. Plus, this is an automotive starter.
Bond-o, if it was NOT the correct one, would it have worked OK? There were no shims or anything when I removed it.
Re: Flywheel
Ayuh,.... There's 'bout 2" difference 'tween the staggered pattern, 'n straight... 1 can never work, where the other was...
