I got a free boat this weekend. It's a Late 60's (66 or 67) Riviera. I got the boat w/ title and trailer although the title won't be available for a couple of weeks.
The hull is in nice shape as well as the window glass and aluminum framing. The deck needs to be pulled out and redone as well as some transom work on which I am going to tackle on my own. It's not too bad but I am 270lbs and feel some weak areas so out it comes. I am pretty mechanical so I think I should be able to do a sufficient deck rebuild. This will give me the opportunity to put a live well and stationary fuel cell in it as well as getting all of the wiring I would need to do out of the way.
It's rated up to a 70hp outboard and I have my eyes set on an Evinrude 60 that I will be buying from a friend. Apparently that motor is in good running order so that should have me set up.
The HIN on this one is RVR14324M79A and I cannot find any info on this boat at all. NADA doesn't have any record of RVR as an HIN prefix.
The last boat I had was a 1985 Bayliner Capri 1600 with an 85 Force outboard. This older boat was put together much better than that Bayliner.
Tell me what you think.
