Taxus812
- Joined
- Aug 5, 2013
- 177
Well I completed fogging my engine the traditional way by spraying fogger into each of the carbs. Then I found this two sentence blurb about using the primer solenoid when I was reviewing the manual for storage procedures today.
So I looked, and what do you know there it is (I think it is in the run position ? )
Is this any better than spraying the carbs individually ?
Next year I'll have to give it a try. The manual didn't provide any other detail on the correct procedure. Can someone explain how to do it ? Also where do I get the tube to connect to it, My Johnson fogger came with a straw.
Once again thanks for the help.
Storage Fogging Oil ? Connect the can to its fitting
on the primer solenoid. Following instructions
on the can, fog the engine. After you fog the engine
be sure the primer solenoid lever is in the run position.
