fogging engine in UK
bijou22
Hi - I have a Volvo Penta 4.3GL which I have just changed the engine oil and filter. This weekend I am also changing the plugs,belts and impeller as I do not know when they were changed last. Then I will remove the boat from the water,change the gear oil give it a general clean down and spray engine with WD-40. Next flush the raw water system,and add some antifreeze to the system. I would like comments on the above and also would I need to fog the engine for storage of 2 weeks while I do a few maintenance jobs on the boat.
rodbolt
Re: fogging engine in UK
for two weeks I would not bother with fogging it.
Ayuh,........ For 2 Months,... Maybe..... 2 Weeks,..... I Wouldn't even Bother........<br /><br /><br />BTW,...... You Need to Resize your avatar,.... It's WAY TOOO BIG..........
Don S
When you flush your cooling system, use something like Salt Away and just drain your system. No need to use antifreeze for a 2 week period.
bijou22
thankyou all for the quick response, sorry about the avatar, i'm new to all this. I have now got rid of it.
