sickwilly
- Joined
- Jul 9, 2007
- 1,089
I have a 2004 4.3 merc carb, alpha I. It has a 2 barrel carb on it.
Yesterday while winterizing I got the motor nice and hot. I then ran it at around 1500 rpm and started to spray in the merc fogging oil. I got through more than half that can without not as much as a slight bit of hesitation, going back and forth between the two openings in the carb.
I then dropped the rpm to idle and proceeded to empty the rest of the can into the carb. I did get some slight hesitation at idle when sraying, but nothing that ever made the engine close to cutting out. So I cut it out manually when I had just a little of the fogging oil left (to spray in after pulling out the plugs).
Is there something I am missing with the directions? Should my engine have stalled?
I definitely think my carb or timing might be off, too rich or lean, because I have had an occasional engine diesel when I shut off. Also, my new plugs looked pretty darn oily after this 40 hour season (pre-fogging oil). Could this have affected it?
Lastly, do people get better results by just pouring in 20 wt oil versus using the fogging oil in the aerosol can?
