squirtbert
Thread starter- Joined
- Jul 2, 2009
- 1
What do you think of the Fold Away Trailer Hinges from Fulton for a 17 ft. older boat that weighs about 1800 lbs?
IMO, if it means the difference between getting the boat in your garage or not, then they are a very good option. They are not very costly and should work well. As tashasdaddy said the weight capacity specs are clearly spelled out and if I remember right are good up to a 5000 pound load. You should be fine. They do require welding though.
