geohei
- Joined
- Mar 16, 2011
- 8
Hello, I have a late model (1998) Force 120. I found in the manual it says to start at 1 turn. I see I should start at 1-1/4 per the sticky. I found other info that says start at 1-1/2. What I found is a get a stable idle at nearly 2 turns out. At 1 -1/2 to 1-3/4 the idle bobs up and down. I'm trying to get it stable and hold just below 1000 rpm in neutral so when I put in gear it doesn't stall (like while docking and going forward to reverse). I have it performing acceptable with that setting (2 turns). Otherwise it runs great. Hole shot is awesome. Any thoughts here? Thanks, GK
PS. I have other posts but started a new one since this is a new topic...
