BradentonBreeze
- Joined
- Nov 26, 2004
- 16
I was searching around for a how to change the lower unit oil on my motor but none were very clear. I have found the vent and fill screws but I hear of a dreaded shift pin screw and I am unsure where it is and where the actual lower unit oil drain screw is. Also where do I get the seals for these screws or would loc tite work? How much oil will I need to do this? Thank you in advance or your input.
